I'm trying to analyze how op amps work in this circuit:
TDA7265 bridge amplifier
To be specific, I'm not sure in what mode the op amps work here and how to calculate their gains.
To analyze the closed-loop gain assuming ideal op-amps you can do a few things to simplify. Ignore the supply bypassing. Ignore the Zoebel networks (R5, C7, R6, C9). Ignore the coupling capacitors and assume DC coupling with a bipolar supply (there is some biasing involved that is not shown). Ignore C8 for now.
Then you have this circuit:
The bottom of R3 is a virtual ground so Vout of OA1 is: (1+36/1.12)\$\cdot\$ V1 = 33.1 \$\cdot\$ V1.
|Output| of OA2 is a bit less (no '+1' factor): -(36/1.12)\$\cdot\$V1 = -32.2\$\cdot\$ V1, so voltage gain is 65.3 or 36.3dB.
The voltage gain of the top amplifier is (36k/560)+1= 65.3 and the same for the bottom amplifier. Since the two amplifiers are bridged then the output gain is double the single amplifier gain so the total gain is 130.6 times.
