I have several questions but I will split it up into two (main) questions.
The first 'series' are about double LED strip 'controller' circuit. Below is the the
I'm intending to use a (5V) 74HC595 through a level shifter as I want it to use on a 3.3V ESP32. The level shifter I didn't show (not so important for the questions I think).
The red dashed box is a part that will not be part of the main PCB, as I don't want to add the 24V power supply on the PCB. Instead it will be a small separate manually made PCB.
The LED strips should be max 3.3A per led strip (of 5 m). Are my following calculations/insights correct (not having an electronic background):
I intend to use a GX16-8 connector for connecting the LED strips to the enclosure, and a JST_XH connector to connect to the PCB. For the JST_XH and GX pins 1 to 4, the max current is 3.3 A / 4 = 0.83 A. Both well within specs of 3A per pin.
Questions:
- Can I use a transistor after the LED strip? In most cases I see them before the LED strip, but afaik it doesn't matter. This way I can place the transistors on the main PCB.
- For the JST_XH and GX pins 5 to 8, the GND is 3A. Since this is just on the limit, I use all remaining pins resulting also in 0.83 A / pin. Maybe there is a small deviation between the GND pins 5-8 as GND finds the shortest way but I assume it will be 'more or less' spread around the pins?
- In the picture below I show the power (the GND of the 12 V LED strips assumes to go through this, I assume this is ok, as all GND needs to be connected together?). I guess I also would need 4 pins for that (thus not unlike the picture just 1 JST XH pin, having 3A max rating, or using a different kind of connector able to handle more than just 3A). Is this true?
