I'm wiring an external piezo as contact mic to the TRRS 3.5 jack of a MacBook Air. I'm following the instructions on this post: Piezo contact mic into iMac - avoid signal spikes
However, the answer to this question is not clear, and the provided link in the answer to this question is now dead.
Where in the circuit should I add the two LEDs to prevent signal spikes? Piezo circuit diagram
I am new to wiring microphones, so please let me know if I am omitting any information that you need to answer this question!
The two LED's should be connected in anti-parallell like this, in order to limit the voltage from the piezo. Schematic with LED's added
By the way, you can often open dead links with Wayback Machine.
  • \$\begingroup\$ Thanks for the information, this is really helpful! \$\endgroup\$
    – Joji
    Feb 5, 2022 at 10:44
