I want to know whether I can use this d-link 3+1 CCTV cable for powering an led strip which runs at 12 volts 1 amp. The led strip is approximately 12 meters away from the smps power adapter. I checked the datasheet of the cable for power ratings on the 3 multi-strand copper wires but they're not given. All that is provided is that there are 14 strands per wire and they're 0.1mm diameter each I think. No cross sectional area or resistance is stated.
2\$\begingroup\$ Calculate the area of each strand. Multiply that by 14 to give you the total current carrying cross section for each wire. Than look that up in a wire gauge table to see what standard wire size comes close (say #26). Finally, use the current rating for that size wire and/or the resistance, current, and your voltage drop requirement to see if it meets your need. You do the work and post it here, and we'll check it for you. \$\endgroup\$– SteveShFeb 5, 2022 at 12:34
\$\begingroup\$ Telecomms equipment and PoE (power over Ethernet) use 48 V to transfer reasonable amounts of power with small diameter wires. \$\endgroup\$– grahamj42Feb 5, 2022 at 22:55
1 Answer
But, you can work that out... a 0.1 mm diameter wire has a CSA (cross sectional area) of 0.007854 mm² and, given that there are 14 of them, that's a net CSA of 0.11 mm².
Then, google an AWG table and see which wire has the closest net CSA. Here's one: -
It looks somewhere between AWG 27 and AWG 26. So, google what the current carrying capacity is of these types of wire: -
It looks like 26 AWG is only really recommended for a maximum current of 361 mA so, you might be out of luck.
I think probably not.
1\$\begingroup\$ That was quick. Thank you for helping me out. I guess I'll invest in a new 0.75mm² copper wire. Should have enough current rating and a lower resistance too. \$\endgroup\$– KokachiFeb 5, 2022 at 12:48
