I'm trying to draw on a monitor by using an FPGA (SPARTAN 3A) and by considering a monitor with 640x480@60 Hz of resolution. In my code, I would like to start from a certain pixel (320,190) and to draw an isosceles triagle with vertex at (320,190) and with height of 100 pixels. To do so, I defined a variable H_address_up which should take the values of the right side (and works properly) and a variable H_address_down which should take the values of the left side, but it just corresponds to its height. I'm not understanding this behaviour and why it is wrong.
If someone could help me, I would be very gratefull.
I attach the code.
module Module_DisplayMonitor(
    input     clk,
    input     rst,
    input     Hdisplay, // it is 1 when the horizontal counter is in the display area
    input     Vdisplay, // it is 1 when the vertical counter is in the display area
    input [10:0]    H_Address, // For horizontal coordinates in the display area
    input [10:0]    V_Address, // For vertical coordinates in the display area
    output reg [3:0] Green,
    output reg [3:0] Blue,
    output reg [3:0] Red
reg signed [10:0] H_increment;
reg signed [10:0] H_address_up;
reg signed [10:0] H_address_down;
reg [10:0] V_increment;
always@(posedge clk) begin
if(Hdisplay && Vdisplay) begin
    H_increment <= 0;
    V_increment <= 0;
    H_address_up <= (10'd321 + H_increment);
    H_address_down <= (10'd319 - H_increment);
    // Triangle
    if (H_Address > H_address_down && H_Address < H_address_up && V_Address > (9'd190 + V_increment) && V_Address < (9'd290)) begin
        //Cyan
        Red <= 4'b0000;
        Green <= 4'b1111;
        Blue <= 4'b1111;
        H_increment <= H_increment + 10'd1;
        V_increment <= V_increment + 9'd1;
        // Black Background
        end else if (H_Address > H_address_up) begin
            Red <= 4'b0000;
            Green <= 4'b0000;
            Blue <= 4'b0000;
        end else if (H_Address < H_address_down) begin
            Red <= 4'b0000;
            Green <= 4'b0000;
            Blue <= 4'b0000;
        end
    end else if (rst) begin
        Red <= 4'b0000;
        Green <= 4'b0000;
        Blue <= 4'b0000;
    end
end
endmodule
    \$\begingroup\$ I’m voting to close this question because it's not EE \$\endgroup\$
    Feb 7, 2022 at 12:41
    \$\begingroup\$ Simulation should answer your question. Even writing some javascript would allow you to test and modify your algorithm. \$\endgroup\$
    – Kartman
    Feb 7, 2022 at 12:43
    \$\begingroup\$ Which monitor? If it scales or zooms the perfectly correct 4:3 video to something else then it is not correct any more. \$\endgroup\$
    – Justme
    Feb 7, 2022 at 13:55
  • \$\begingroup\$ I don't know what you think the mathematical description of a triangle is, and that isn't it. What's going on with all of those "up", "down" and "increment" signals? \$\endgroup\$
    – Dave Tweed
    Feb 8, 2022 at 1:07
Try something like this as the body of your module:
  parameter v_start = 11'd190;
  parameter v_end   = 11'd290;
  parameter h_center = 11'd320;
  /* "width" starts counting up from zero starting at the v_start line.
   * We then define the first and last pixels of the triangle on each line
   * based on width.
  wire [10:0] width = V_Address - v_start;
  wire [10:0] h_start = h_center - width;
  wire [10:0] h_end = h_center + width;
  always @(posedge clk) begin
    if (Hdisplay && Vdisplay) begin
      /* active display area */
      if ((V_Address >= v_start) && (V_Address <= v_end)
        && (H_Address >= h_start) && (H_Address <= h_end)
      ) begin
        /* pixels that are in triangle (cyan) */
        Red <= 4'b0000;
        Green <= 4'b1111;
        Blue <= 4'b1111;
      end else begin
        /* pixels not in triangle (black) */
        Red <= 4'b0000;
        Green <= 4'b0000;
        Blue <= 4'b0000;
      end
    end else begin
      /* blanking (black) */
      Red <= 4'b0000;
      Green <= 4'b0000;
      Blue <= 4'b0000;
    end
  end
