I have a wifi module (Advantech WISE-4220) shown in this datasheet.
If I remove the outer plastic casing and put the chip/antenna, unmodified, into another plastic case, am I breaking any FCC regulations/laws?
Any citations are appreciated.
Edit: I no longer intend to modify the unit. I plan on putting the unit, unmodified, into a pushbutton box. The new question is can I do this without seeking FCC approval. After some reasearch I think I only have to declare that the pushbutton box contains an FCC approved device with [FCC ID] and that the pushbutton box needs a minimum distance from an operator for safe operation.
