I am currently building a robot (as some of you may know from my previous questions). The current task I a dealing with is that of communication. To keep things simple, assume I have 5 commands to deliver from my ground station to my robot:
- Drive forward
- Drive reverse
- Activate servo 1
- Activate servo 2
- Motor speed
Now, I am sending these commands from my computer to a USB to Serial adapter and then over an RF link. But this is not important, as far as I know, to my question.
So my question is, how does communication work in general? My idea is that I will have five different 8 bit data packets (one for each command) which I will continuously send from my computer. So I will keep an infinite loop going which will check, say, the position of an analog joystick. If it is pointing upward, command 1 will carry the drive forward message. If it is pointing downward, command 2 will carry the message, etc. Depending on how far the joystick is in the up/down position will dictate the contents of command 5. And the state of some keys on the keyboard will dictate whether commands 4 and 5 contain info to actuate servos.
So, again, I plan on having a continuous loop which will check each of the 5 states and send the appropriate commands over the USART from the computer's side.
The problem I am having, conceptually at least, is that what if there is a lag on the robot's end to process the data coming through the USART? As I understand, to ensure data isn't lost, the data is stored in a buffer on the MCU. Essentially, I want a "last in first out" system on my robot, so even if I miss the older commands for whatever reason, the robot is doing what I want it to do now, not what I wanted 2 seconds ago. But with this methodology, I'm also afraid that I will skip data packets of commands 1-4 because it will just keep reading the last data packet (i.e. command 5).
I came up with this communication "roadmap" on my own, so I'm sure there are much better ways to accomplish what I want. But I hope you understand what I mean. Also, I am using an ATmega328 on my robot, if it matters.
I would appreciate any advice pertaining to this situation.
