If I connect my ESP32 board to my PC via USB and upload any code via the Arduino IDE, all works fine.
Even if I disconnect the USB cable, when I reconnect it, the ESP32 board restarts and works perfectly.
If I disconnect the USB cable and power the ESP32 board by means a reliable power source (https://www.tek.com/en/products/keithley/dc-power-supplies/2220-2230-2231-series) either from Vin (5V) or 3.3 V, the ESP32 board doesn't work in any way even though the onboard LED is ON.
In detail:
The ESP32 acts as a BLE server to which a BLE client is connected configured on another ESP32 board running under Home Assistant.
Powering via USB, the BLE server sends data to the BLE client on Home Assistant. When I disconnect the USB cable from the PC and connect the ESP32 to an external power source it stops sending data in any way.
Any idea?
    void setup()
  Serial.begin(115200);
  pinMode(25,OUTPUT);
  Serial.println("Visualizza quanto trasmesso dal BLE Client a questo BLE Server: ");
  BLEDevice::init("MyESP32-Cosimo");
  BLEServer *pServer = BLEDevice::createServer();
  BLEService *pService = pServer->createService(SERVICE_UUID);
  BLECharacteristic *pCharacteristic = pService->createCharacteristic(
                                         CHARACTERISTIC_UUID,
                                         BLECharacteristic::PROPERTY_READ |
                                         BLECharacteristic::PROPERTY_WRITE
  pCharacteristic->setCallbacks(new MyCallbacks());
  //pCharacteristic->setValue("Hello World");
  std::string value = "Hello World";
  pCharacteristic->setValue(value);
  pService->start();
  BLEAdvertising *pAdvertising = pServer->getAdvertising();
  pAdvertising->start();
void loop() {
  // put your main code here, to run repeatedly:
  delay(2000);
  • \$\begingroup\$ More information is needed. Assuming you are using an ESP32 devboard, which one is it ? What is the Vin that you are referring to ? \$\endgroup\$
    – mpetitjean
    Feb 8, 2022 at 10:53
  • \$\begingroup\$ @mpetitjean You're right. I've just added a photo... \$\endgroup\$
    – M4Biz
    Feb 8, 2022 at 11:03
    \$\begingroup\$ What does "it doesn't work" mean? The lights are on as you expect, so what behavior indicates to you a problem? Please describe in detail the expected and observed behaviors. \$\endgroup\$
    – TypeIA
    Feb 8, 2022 at 11:23
    \$\begingroup\$ Do you by any chance have something like while (!Serial) ; in your setup or loop? \$\endgroup\$
    – DamienD
    Feb 8, 2022 at 11:30
    \$\begingroup\$ To debug things further I would blink the LED in the loop function, so you know if it's actually running. \$\endgroup\$
    – DamienD
    Feb 8, 2022 at 15:17
Problem solved.
It was only a bad ESP32 board .
It works when powered by USB and don't in anyway if powered by external source. Replacing it with a new, identical, board, it works fine even if is powered by 5V than 3,3 V.
