This is a battery charging circuit. The part I don't understand is the block on the lower right. What does that dashed rectangle mean, the ellipse around the resistor? and the encircled dots?
The datasheet is here.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityThis is a battery charging circuit. The part I don't understand is the block on the lower right. What does that dashed rectangle mean, the ellipse around the resistor? and the encircled dots?
The dashed rectangle typically means a remote part, off-board, or removable. In context this is a battery charger for a removable battery pack, as you see in the description right above that typical application you screenshotted.
The resistor isn't a plain resistor. It's a NTC temperature sensor. Its resistance changes as the temperature does. Typically used as feedback of battery status. If it's too hot, it signals the charger to stop. See page 16 for how the NTC functions here.
And the encircled dots are jacks. Like RCA jacks. Just a simple connector. Typically that symbol is used for 2 conductors (center dot and the outer circle) but here it's been made a bit abstract.
The resistor with the ellipse is a thermistor with a beta value (B) of 3380. The beta value describes the resistance versus temperature curve. The dashed box indicates that the thermistor is thermally coupled to the battery so the device can measure the battery temperature. Should the battery temperature increase to an unsafe level, the charger will so something to prevent over temperature. See data sheet page 7, NTC (Pin 8); and page 16.
indicates that the parts shown inside are a single module
It means it's a thermister, a circle would indicate a photo-conductor
Being inside the box with the battery it's probably meant to be thermally connected, eg with aluminium tape.
I'm guessing it indicates some sort of connector.
Oddly they don't show a connector for the ground end of the battery or thermister
It is an accepted symbol for a coaxial connector, but here they are surely using it to mean single-wire a join. Odd.
