In a flyback converter, we have the freedom to choose appropriate duty cycle by adjusting the turn ratio to meet the desired output voltage.
The link says
Developers will need to know several key parameters when starting a design, along with the basic electrical specification. Begin by selecting a switching frequency (fsw), a maximum desired operating duty cycle (Dmax), and an estimated target efficiency".
How do we come up with desired duty cycle? Is it based on the datasheet graphs corresponding to highest efficiency?
In general a buck-boost converter (parent converter of flyback) is having higher efficiency at low duty cycles.
Text book excerpt
  • \$\begingroup\$ Your opening statement is incorrect. When operating in DCM, altering the turns ratio does not affect duty cycle for a given load and supply voltage. In CCM it will but not in DCM. Maybe you need to state why you said this so that there is context because it puts me off answering having incorrect assertions that you believe are correct. \$\endgroup\$
    Feb 9, 2022 at 8:18
  • \$\begingroup\$ The link in your question is also really quite bad. It states that DCM is characterized by the converter having its rectifier current decreasing to zero before the start of the next switching cycle - all flyback converters have this characteristic (DCM and CCM) so, right away, the article is off to a bad start and cannot be trusted. \$\endgroup\$
    Feb 9, 2022 at 8:26
    \$\begingroup\$ You can have a look at my APEC 2011 seminar, The Dark Side of Flyback Converter in which I cover many aspects of the flyback converter operated in different modes. \$\endgroup\$ Feb 9, 2022 at 8:30
  • \$\begingroup\$ A very crude method is to just assume 40 % duty cycle and see where you end up. It’s far from perfect but it will get you started. \$\endgroup\$
    – winny
    Feb 9, 2022 at 9:22
Begin by selecting a switching frequency (fsw), a maximum desired operating duty cycle (Dmax) ...,
You made it italic to take the attention but it appears that you missed it.
Normally you don't come up with a "fixed" duty cycle. Due to the nature of the converter (like in the others), the controller adjusts the duty cycle when the input voltage changes: The controller increases it as the input voltage decreases.
So first, you need to decide the minimum input voltage for your converter, and then you must decide the maximum duty cycle at that minimum input voltage.
Depending on the topology and the controller IC, there might be a limit for the duty cycle. For example, for buck and boost there's no liimt. For 2-sw forward it's limited to 50%. For DCM flybacks there's no theoretical limit since it's all about the volt-seconds balance but in practice it's better to keep it below 50% to guarantee a proper reset and for the sake of the primary switch's health (The higher the duty-cycle the higher the reflected voltage and thus the primary switch stress). For CCM flybacks, it can be way higher than 50%.
  • \$\begingroup\$ In DCM you can have duty cycles more than 50% (D = charge duration ratio to switching period). \$\endgroup\$
    Feb 9, 2022 at 8:16
    \$\begingroup\$ @Andyaka yeah you're right and it's actually about the volt-seconds balance. We keep it below 50% in practice for the sake of the switch's health. That's why I wrote it so but it appears that I chose wrong words. Thanks for pointing out. \$\endgroup\$ Feb 9, 2022 at 9:05
That is half-right and half-wrong.
A flyback converter may operate wholly in continuous conduction mode (CCM) when the minimum load current is not too low. However, if the load range also covers quite light currents then, it's likely that the flyback converter will drop into discontinuous conduction mode (DCM).
  • In DCM, the transformer turns ratio does not affect the choice of duty cycle.
  • In CCM, the transformer turns ratio does affect the choice of duty cycle.
Consider this scenario of a 1:1 isolating transformer producing 100 volts out with a supply of 100 volts DC. It operates naturally in DCM in this first scenario: -
The duty cycle is 44.721% and, if I changed the turns ratio to 2:1 we would see this: -
Despite the turns ratio changing, the duty cycle remains at 44.721% and still in DCM.
Images from my somewhat incomplete flyback calculator page.
If I lowered the turns ratio to 0.5 the circuit would enter CCM and, at that point, duty cycle does change with the turns ratio value: -
Now it is 33.333% and if I lowered the turns ratio to 0.25 the duty cycle drops to 20% (still in CCM): -
How do we appropriately select the duty cycle in a flyback converter?
and
Well, you have to understand the two modes of operation (DCM and CCM) and their respective voltage transfer ratio formulas: -
  • In CCM, the transfer ratio is influenced by the transformer turns ratio and, because it has one-less degree of freedom compared to DCM, the output voltage is dictated by the primary and secondary currents forming a continuously changing flux in the core without it falling to zero. This makes it behave like a voltage regulator.
  • In DCM, the transfer ratio isn't influenced by the transformer because the flyback circuit is behaving like a power regulator; energy is swallowed by the primary during charge and wholly given to the secondary during the transfer phase of switching.
The link says
The link in your question is also really quite bad. It states that DCM is characterized by the converter having its rectifier current decreasing to zero before the start of the next switching cycle - all flyback converters have this characteristic (DCM and CCM) so, right away, the article is off to a bad start and cannot be trusted. Ignore that article is my advice.
