My motherboard (Gigabyte b450) died after a power outage. I found out that an SMD 5-pin IC with the code VA8qE was burned. I tried to identify it myself, with no luck.
I searched for the code online, but no result, even on pages like:
Any idea what it is?
    \$\begingroup\$ Not found as a Code or PN . Is there another number? or brand symbol sphere.bc.ca/download/smd-codebook.pdf \$\endgroup\$ Commented Feb 10, 2022 at 17:52
    \$\begingroup\$ A detailed photo of the motherboard and the burnt part might help get you an answer. \$\endgroup\$ Commented Feb 10, 2022 at 18:05
    \$\begingroup\$ UPDATE: with actual picture of the component, seem that 5 pic give voltage to the ITE chip. there is a exact chip near the chipset, i removed that one and replaced the burned, now the mobo turn on, but no video, so i sill need to replace it. \$\endgroup\$
    – Androsk
    Commented Feb 10, 2022 at 18:14
  • \$\begingroup\$ Could it be one of the "VAB" components listed at smd.yooneed.one/code5641.html ? Does the working one have an output of 1.1 V? \$\endgroup\$ Commented Feb 10, 2022 at 18:47
I think it says "VAB", in which case it's probably a S-1135 Series voltage regulator.
More specifically the "S-1135C11-M5T1y", according to the datasheet.
Doing some reading with the multimer on the same 5 pin not burned VA8qE next to the chipset, it looks like it a voltage regulator, 5 V input 3.3 V output. I found (different code) in an old motherboard I had around, measure, and the MOBO is live again, booted to BIOS so far.
