I am building a heat sensor circuit using this circuit model.
What I understand is that the \$\beta\$ parameter of the NPN transistor is temperature dependent. Increasing the temperature, i.e, lighting something in front of the transistor, increases the collector current and hence the LED turns ON.
I don't understand the resistor arrangement. I can see that the diode is keeping the base-emitter junction in forward bias ,but why is this necessary? I believe the potentiometer is supposed to maintain the sensitivity, but how is it doing it?
I want to understand how this circuit works.
The circuit model can be found here.
    \$\begingroup\$ Which component is the heat sensor? \$\endgroup\$
    – HandyHowie
    Feb 11, 2022 at 13:55
    \$\begingroup\$ You've drawn that circuit for a reason so, why did you draw it - is it based on something you found on-line? If so then it's far preferable to copy and paste that diagram rather than draw your own version. Please link to the source information and add a picture from that information. \$\endgroup\$
    Feb 11, 2022 at 14:05
  • \$\begingroup\$ @Andyaka, yes I have edited my post now, and the pictures are identical \$\endgroup\$ Feb 11, 2022 at 14:43
  • \$\begingroup\$ This will dim to 1% of the current in the 1st 20% of the turn of the pot \$\endgroup\$ Feb 11, 2022 at 14:51
  • \$\begingroup\$ Otherwise as the diode heats up at -2mV/'C a 100mV drop to Vbe translates to a 50 'C rise \$\endgroup\$ Feb 11, 2022 at 14:56
The diode forms a crude reference. It is assumed to be at constant (room) temperature. If you heat the diode up you'll get an opposite effect to heating the transistor.
The effect is primarily due to the Vbe of the transistor decreasing, thus tending to turn it on as the temperature rises, not hFE.
Here is a simulation with the transistor heated from 20°C to 200°C (pot set at 50%):
The plot indicates LED current. Depending on the LED it may be pretty visible at a fraction of 1mA.
If you want a more stable sensing for a few pennies more you can connect the transistor as a diode, add a reference (eg. TL431) and use a comparator or an op-amp to do the comparison.
BE on the Transistor is a diode as well. With the diode D1 you're basically making a low reference voltage that can be set more precisely with the potentiometer.
You set the brightness to room temp and the use the diode as a heat sensor isolated from the transistor at room temp.
The PN junction has a NTC value approx -2mV/+1'C with the initial somewhat balanced current shared between diode and Vbe and the LED is ON. As the diode heats up Vbe drops due to the diode voltage dropping as it draws more current and the base draws less current and the LED gets dimmer.
The relationship of Vbe to Ic is a quadratic one and even if the hFE was constant the base current is not a linear one even with a fixed low base resistance in the pot as the transistor Vbe also changes with base current. In the end it is exponential so if a 50'C rise was considered full scale minimum LED current, the 25'C rise won't exactly be the mid-point of LED current. But it will indicate an inverse brightness with diode temp rise.
