Why are most common mode chokes only given with a impedance curve, inductance at a specific frequency and current rating (this is clear😅).
Wouldn't be S-parameter better? I know it's more work, but what can I calculate with the impedance?
Thanks
  • \$\begingroup\$ Please give an example and why would an S parameter be useful for common mode impedance? S parameters assume a fixed load impedance and, in many, many cases that would be useless. \$\endgroup\$
    Feb 11, 2022 at 16:50
  • \$\begingroup\$ This one for example (the first one I could find without S-Parameter): mouser.de/datasheet/2/447/P789-2902987.pdf \$\endgroup\$
    – R098
    Feb 11, 2022 at 16:53
  • \$\begingroup\$ Or like this mouser.de/datasheet/2/212/1/KEM_LF0030_SS26V-1103810.pdf \$\endgroup\$
    – R098
    Feb 11, 2022 at 16:55
    \$\begingroup\$ Certainly not. Have you tried a search? \$\endgroup\$
    – winny
    Feb 11, 2022 at 16:58
    \$\begingroup\$ @schedan that's matches up with my searching, with Ethernet Common Mode Chokes there are mentioned the S-Parameters. But for general purpose ones only sometimes. Some of them could also be used on Power Lines, but there we have my question again? What does the Impedance give me?😅 \$\endgroup\$
    – R098
    Feb 11, 2022 at 17:30
most common-mode chokes only give an impedance curve, inductance at a specific frequency and current rating.... why not s parameters?
TL:DR ;)
Some day you may find s parameters for RF CM chokes. It's a good idea for a limited application with 50 Ohm ports.
But in general, that is not the case as it is the impedance ratios that matter for Z{CM/DM} with some frequency dependant load or the degradation of an INA CMRR (instr. Amp) due to slight wire CM impedance mismatches.
The different purposes of a Balun or CM choke affect the choice of CM choke and its design for noise reduction on Grid, SMPS harmonics, RF interference on Ethernet, VGA noise emissions and converting unbalanced 50,75 lines to more balanced lines. But the primary reason is to raise CM impedance for some load relative to the Impedance of each line. Ideally, a CM choke should not add any differential impedance if perfect coupled lines. (M=1 & DCR=0)
When this happens with CM interference how much is injected? what is the attenuation? Attenuation and reflections are shown with s parameters but may not be relevant for the Choke until the reactive or resistance load is added. You could create s-parameters for a 50 Ohm load, but some chokes are not used for that impedance such as power supplies.
The more significant parameter not mentioned in datasheets is the degree of mismatch in the CM impedance. It is this overall mismatch that ultimately determines the CMRR or ratio of attenuation of CM/DM into some load with some external CM interference and DM signal.
Low inductance bifilar wound use twisted-pair magnet wire. For DIY one can use a single magnet wire then folded in half and twisted so the inductance in each leg is almost identical within 0.5% then wound around some core with the midpoint split open to form the other port.
High inductance CM chokes will wind the same number of turns on opposite sides but may have a slightly worse matching due to differences in the high permeability MgZn on either side.
reading material
https://www.semanticscholar.org/paper/Insertion-loss-analysis-of-low-voltage-power-line-Kurniawan-Basuki/b8acc43b921d7f78c5d9410e8a96e7af7182a6ba
Magnetics tend to be custom, so there may be a limited selection of stock items, yet there are millions of combinations of material properties and design to meet specs when feasible. In some situations, I have improvised with 1:1 signal transformers with high inductance.
How to do Scattering parameters with CM choke for 50 Ohms.
https://www.researchgate.net/profile/Jorma-Kyyra/publication/224600584_Common-mode_choke_coils_characterization/links/0c96052bddccc487be000000/Common-mode-choke-coils-characterization.pdf
"it is worth nothing that according to (1), when k = 1, i.e. assuming M = L, then Lcm = 0 and Ldm = 4L. Therefore, a coupled DM inductor is very different from two decoupled DM inductors, which would result in Lcm = L/2 and Ldm = 2L."
