7
I found following component but don't know what it is. In particular what does the ΩJ unit mean?
  • 10
    \$\begingroup\$ the J is likely a separate symbol, probably referring to tolerance. \$\endgroup\$
    – Hearth
    Feb 18 at 14:36
19
That's not J for joules. It's probably J for 5% tolerance. The component is just a 10 mΩ resistor with a 5 W rating.
    \$\begingroup\$ Probably we have a dupe somewhere on the site for this kind of code, but I wasn't able to turn it up with a bit of searching. \$\endgroup\$
    – hobbs
    Feb 18 at 14:37
  • 5
    \$\begingroup\$ electronics.stackexchange.com/a/484095/47070 \$\endgroup\$
    – JRE
    Feb 18 at 14:40
17
"J" means a resistor value tolerance of +/- 5% as per this site.
The resistor in question has a value of 10 milli-ohms (\$m\Omega\$).
It also applies to capacitors as per this wiki site: -
