I am experiencing a strange problem with reading back the value of PORTD
while it is configured as an output. I am writing to LATD
to set output on the port. The actual output is as I expect (verified with LEDs), but when I then read the value of PORTD
, bits 0:3 always come back as zero...
My first thought was conflict with the ADC, but it is switched off, as are CCP1, ECCP and PSP which also share pins with port D. The code works fine when running in MPLAB SIM but the problem shows up both running normally and debugging with a PICkit3...
Here's the code:
void main (void)
char test;
ADCON0bits.ADON=0; //Turn adc off
ADCON1 = 0x0F; //Turn individual ADC channels off.
ECCP1CONbits.ECCP1M = 0; //Turn off ECCP module
CCP1CON = 0; //Disable CCP1
TRISEbits.PSPMODE = 0; //Turn off PSP module
TRISD = 0; //PORTD to output
LATD = 0xFF; //Set all bits high
Nop(); //Wait for output to propagate back to PORTD
test = PORTD; //test gets 0xF0???
This is really frustrating, all the more so because the hardware actually functions but my self tests keep giving false positives...
LATD
instead ofPORTD
(the difference) would probably solve the problem, but this is strange and needs clarification. Can you check the voltage on the different pins with respect to ground? \$\endgroup\$
