Feedback Basics
Let's start with the two feedback situations, just to be pedantic. (Only the left side applies to the given opamp situation.)
Let's use the freely available sympy to work out the resulting closed-loop equations. Since I don't want to assume anything about the input and the output (whether voltage or current or whatever), I'll use p for process variable:
var('aol b pin pout')
solve(Eq(pout, (pin-b*pout)*aol),pout)[0]/pin
aol/(aol*b + 1)
solve(Eq(pout, (pin+b*pout)*aol),pout)[0]/pin
-aol/(aol*b - 1)
So the results for feedback that is applied as negative are \$A^{^\text{-}}_{_\text{CL}}=\frac{A_{_\text{OL}}}{1+A_{_\text{OL}}\,\beta}=\frac1{\frac1{A_{_\text{OL}}}+\beta}\$ and the results for feedback that is applied as positive are \$A^{^\text{+}}_{_\text{CL}}=\frac{A_{_\text{OL}}}{1-A_{_\text{OL}}\,\beta}=\frac1{\frac1{A_{_\text{OL}}}-\beta}\$.
As \$A_{_\text{OL}}\to\infty\$, \$A^{^\text{-}}_{_\text{CL}}=\frac1{\beta}\$ and \$A^{^\text{+}}_{_\text{CL}}=-\frac1{\beta}\$. (You can trivially solve for \$\beta\$, as well.)
Hopefully, that's clear.
Figure 1
Before diving into this one, it's worth stopping a moment to consider it. There's a current source/sink input (which may or may not be dependent upon time) at the negative opamp input node. Assuming an ideal opamp, whose negative input node neither sinks nor sources current, the current source/sink's instantaneous value must be matched by the sum of currents through the two capacitors. However, \$v_{_\text{X}}\$ (little-v used here for time-domain) must always be kept at ground (assuming an ideal opamp that responds instantly.) So it follows that there cannot be any current in \$C_{_\text{PD}}\$ and therefore all of the matching current must be coming solely through \$C_{_\text{INT}}\$.
Applying KCL, you know that:
$$i_{_\text{PD}}=C_{_\text{INT}}\,\frac{\text{d} }{\text{d} t}\:v_{_\text{OUT}}$$
If we stay in the time-domain, the time derivative of \$v_{_\text{OUT}}\$ multiplied by \$C_{_\text{INT}}\$ is that current. So we'd need to solve an integral to get back \$v_{_\text{OUT}}\$.
Usually, it's easier to just avoid such issues by staying in s-space where integral and derivative problems are reduced to simpler algebra problems. So the above equation is then (using capitals to represent the Laplace-equivalent variable names):
$$\begin{align*}
I_{_\text{PD}}&=C_{_\text{INT}}\,s\:V_{_\text{OUT}}
\\\\\therefore\\\\
V_{_\text{OUT}}&=I_{_\text{PD}}\cdot\frac1{s\,C_{_\text{INT}}}
\\\\\therefore\\\\
A^{^\text{-}}_{_\text{CL}}=\frac{V_{_\text{OUT}}}{I_{_\text{PD}}}&=\frac1{s\:C_{_\text{INT}}}
\end{align*}$$
But that's just the s-space impedance for \$C_{_\text{INT}}\$. All this means is that \$I_{_\text{PD}}\$ is pulled or pushed through the impedance of \$C_{_\text{INT}}\$ to get \$V_{_\text{OUT}}\$. Which makes a lot of sense.
Note: So why even bother specifying \$C_{_\text{PD}}\$? The reason has to do with noise analysis which is beyond your question here.
From the prior section, we know that \$\beta=\frac1{A^{^\text{-}}_{_\text{CL}}}=s\:C_{_\text{INT}}\$.
Let's just directly use KCL to find the transfer function:
var('cint cpd ipd vx vout iout s')
CINT = 1 / (s*cint)
CPD = 1 / (s*cpd)
eq1 = Eq( vx/CINT + vx/CPD + ipd, vout/CINT ) # KCL for Vx node
eq2 = Eq( vout/CINT, iout + vx/CINT ) # KCL for Vout node
eq3 = Eq( vx, 0 ) # opamp's goal
ans = solve( [ eq1, eq2, eq3 ], [ vout, vx, iout ] )
ans[vout]/ipd
1/(cint*s)
That's nice to see.
(Also note that using KCL also causes \$C_{_\text{PD}}\$ to drop out of the solution. This is expected because of our prior analysis saying that there is no current through it.)
Figure 2
Let's just dive into the KCL for this one:
var('r1 r2 vin vx vout iout s')
eq1 = Eq( vx/r1 + vx/r2, vin/r1 + vout/r2 ) # KCL for Vx node
eq2 = Eq( vout/r2, iout + vx/r2 ) # KCL for Vout node
ans[vout]/vin
-r2/r1
Again, from the first section we know that \$\beta=\frac1{A^{^\text{-}}_{_\text{CL}}}=-\frac{R_1}{R_2}\$.
That also makes sense. If you lower the input impedance (treating \$R_1\$ as the input impedance of the input voltage source) then the negative feedback factor is smaller as a result. Similarly, if you lower the output impedance (back to the input node and, again, treating \$R_2\$ as the output impedance of the output as seen by the input node), the negative feedback factor is larger as a result.
