VHDL has a clear distinction between signals and variables. Variables are always updated as soon as we assign a value to them. However, a signal is only updated at the end of the process block.
In Verilog and SystemVerilog there is no distinction like variable and signal found in the VHDL. However, here we have the concept of blocking and non-blocking assignment. The non-blocking assignment behaves like the variable in VHDL while the blocking assignment behaves like the signal in VHDL. Atleast this is my conclusion.
Now the issue is that, it is allowed to mix blocking and non-blocking assignment for the same reg or logic type in Verilog/SystemVerilog. This brings me to my question (about synthesizeable code):
- I assume that mixing blocking and non-blocking assignments for synthesis code for the same reg or logic type, is a bad idea. Why is it allowed in the language?
- How does one make sure that mixing of blocking and non-blocking assignment for the same reg or logic type does not happen (by mistake)?
- Is it a good practice to have blocks of code that combine reg or logic types like we can have signal and variable in the same VHDL process?
Note: This question is not asking about difference between the blocking and non-blocking assignments
" -- A good designer doesn't mix it. As simple as that. However linting tools can catch this, not sure about RTL compilers or synthesisers. \$\endgroup\$
