I'm designing a DC-DC buck converter and when looking at the inductor's datasheet, I noticed an image showing a restricted area underneath the inductor, between the pads.
https://www.we-online.com/catalog/datasheet/74439346047.pdf
Presumably the dashed line (that's approximately 6.5mm) is the restricted area, and that covers the perimeter of the inductor, not just a pair of brackets [ ] around the pads.
I would generally avoid putting feedback/compensation/current sense traces between the pads, at least on the same layer, to reduce the risk of inductive pick up, but for a shielded inductor such as this, I might be a bit more willing to utilise the space, especially other layers.
It just so happens that on my current design, which is very restrained mechanically, I could really do with putting some ground stitching vias between a mid-plane and bottom copper - smack-bang in the middle between the pads. Note they would be through vias, not blind.
I don't recall seeing this keep-out area on other shielded inductors from different manufacturers such as Bourns or Abracon.
Should I change my views on this from rule-of-thumb to hard rule and convince the mech-eng to give me more space, or go for it and hope for the best?
