I'm working on a project and I need to power some RGB LED strips; three strips that need 12 V, 5 A each. The thing is that I have one switched-mode power supply of 12 V, 10 A and some 12 V, 5 A power supplies that came with the LED strips/ I assume these are linear supplies.
So the SMPS was already installed; can't I add one of those 12 V, 5 A LED supplies in parallel with the SMPS to get the 15 A needed for three RGB LED strips?
The RGB LED strips will be controlled by an Arduino and all will have a common ground.
