How do I measure the characteristics of a voltage divider in QUCS?
Below is what I have tried thus far, using Qucs 0.0.15 on Ubuntu 10.04
I want to measure how the voltage at the center of a voltage divider changes based on R2 in the schematic below. I am attempting to simulate this in QUCS using a DC simulation and a parameter sweep.
This is how I have it set up below, but the output is constant from what I can tell, which does not make sense.
graph setup tabular output
Like SPICE simulators there's a difference between simulation parameters and reference designators.
Here, the reference designator for the lower resistor is R2. The R value of R2 is always 50 ohms. To use a parameter, you must assign it to the parameter name surrounded by curly braces. So the R value of resistor R2 should be {R2} to have resistor R2's R value set to the parameter R2.
To make things a bit more clear, change the parameter sweep param to RLOW and the value of R2 to {RLOW}. The simulation should work as expected and you'll get the correct results (yeah, I realize that my voltage source isn't at the same level as the OP so the actual values will be different).
results
  • \$\begingroup\$ Bless you! That worked wonderfully. \$\endgroup\$
    – JonnyRo
    Mar 15, 2013 at 5:49
  • \$\begingroup\$ Stack exchange is the coolest system out there! \$\endgroup\$
    – JonnyRo
    Mar 15, 2013 at 5:50
  • \$\begingroup\$ I don't think you need the curly brackets in QUCS \$\endgroup\$
    – endolith
    Aug 28, 2015 at 19:04
