I'm putting together an enclosure to hold the transformer and dimmer for a small neon sign. I'm quite comfortable with normal AC/DC stuff, but the output from the neon transformer is super high voltage!
The transformer:
- Ventex VT5520A-120F
- Output: 2.9kV RMS 24mA
Is this safe to do? Or do these always need to be hard-wired?
If this is possible, can anyone suggest a connector that would be appropriate for this? I'd like the leads for the sign to be able to be detached and re-attached periodically. (Seems like a connector that screws on would be best here, to avoid coming loose.)
