I'm doing a "Snap Circuits" project which is supposed to demostrate that a mini DC motor can act as a generator and light an LED. Following the instructions provided, I made the following circuit. When SW1 is open, the LED turns. When SW1 is closed, the LED turns off. I think this is because when SW1 is closed, there is little resistance in the stationary DC Motor and so all the circuit current flows through the DC Motor and none through the Transistor. With SW1 closed, if I spin the DC motor shaft with my fingers, the LED flashes. According to the project instructions, the LED lights because the DC Motor is generating voltage when I spin the shaft. I don't think this is why the LED is flashing. If I turn the shaft very slowly my multimeter registers about 10mV being generated and the LED still flashes. It almost seems that when I slowly spin the DC motor shaft, the current through the DC Motor is being intermittently interrupted, and the circuit is behaving as if I've opened SW1. Can anyone shed any light on what is happening with this circuit? Thanks!
I tried to simplify the original "Snap Circuits" project design and maybe I did this incorrectly. Here's the original design: enter image description here
  • \$\begingroup\$ That is a really strange way of demonstrating what they're trying to demonstrate. Are you sure the schematic is correct? If you're in any doubt at all, maybe post a photograph or screen shot of their schematic? \$\endgroup\$
    – TimWescott
    Feb 27, 2022 at 22:03
  • \$\begingroup\$ Put the switch in the line between the battery +, and R2. \$\endgroup\$
    – Chu
    Feb 28, 2022 at 1:21
  • \$\begingroup\$ I've added the original "Snap Circuits" design to my post. In trying to simplify the design perhaps I did it wrong - not sure. \$\endgroup\$ Feb 28, 2022 at 13:47
  • \$\begingroup\$ Even if the circuit diagram I used is strange, I'd still like to understand why it behaves as it does. \$\endgroup\$ Feb 28, 2022 at 13:49
What their version does
They've set up the transistor and it's associated resistors (R5, R4, R1 and the potentiometer) to detect when current is injected into the transistor base from the motor via C5. When you inject current into the base, Q2 turns on, and the LED lights up.
Basically, the chain of resistors from the positive power rail to the transistor base try to turn the transistor on, while R4, from the base to ground, keeps it turned off.
When you spin the motor, extra current is injected into the base via the \$470\mu\mathrm F\$ capacitor, until the capacitor charges up. This turns on the transistor, which conducts electricity, and that makes the LED glow.
Why your version didn't work
DC motors work because they have a commutator and brushes. A commutator and set of brushes is basically a switch that's actuated by the motor that always energizes the correct set of motor coils in the correct direction so that the motor turns.
With an inexpensive motor, the commutator doesn't always make contact -- sometimes it does, indeed, open up, and this would be just like your SW1 opening up.
Going Further
They've chosen what is, in my opinion, an overly complicated way of demonstrating what they're trying to show. For the right motor/LED combination, you should be able to just connect the LED across the motor, spin it fast enough and in the right direction, and see it light up. If you use two LEDs in anti-parallel, then spinning the motor in one direction would light up one LED, and spinning up the motor in the other direction would light up the other LED.
It could be that with the motor they've chosen you'd have to be especially good at spinning the motor to get it going fast enough -- to do that really "right" you'd need a gear train and a crank, and then you'd pretty much have a dedicated generator, or at least a project that's more mechanical than electrical.
But, if you connect the circuit as they've shown, it should work.
If you want a deeper dive, here's a video I did on how a brushed DC motor works. I can't remember if I went into any depths as to how it works as a generator, but the short story is if you use electro-magnetism to move something, then that same mechanism can almost always be a generator, too.
  • \$\begingroup\$ Thanks for the reply, and the link to your video. The video was fantastic! Thanks so much. I've revised my original post to add the "Snap Circuits" design which in my attempt to simplify I might have changed incorrectly. \$\endgroup\$ Feb 28, 2022 at 13:49
