I'm trying to enable or disable two DAC outputs of STM32F407 board. STM32CubeMX tools shows the following options:
Above I choose both output buffers as Enable.
And the auto generated code is as follows:
static void MX_DAC_Init(void)
  /* USER CODE BEGIN DAC_Init 0 */
  /* USER CODE END DAC_Init 0 */
  DAC_ChannelConfTypeDef sConfig = {0};
  /* USER CODE BEGIN DAC_Init 1 */
  /* USER CODE END DAC_Init 1 */
  /** DAC Initialization
  hdac.Instance = DAC;
  if (HAL_DAC_Init(&hdac) != HAL_OK)
    Error_Handler();
  /** DAC channel OUT1 config
  sConfig.DAC_Trigger = DAC_TRIGGER_NONE;
  sConfig.DAC_OutputBuffer = DAC_OUTPUTBUFFER_ENABLE;
  if (HAL_DAC_ConfigChannel(&hdac, &sConfig, DAC_CHANNEL_1) != HAL_OK)
    Error_Handler();
  /** DAC channel OUT2 config
  if (HAL_DAC_ConfigChannel(&hdac, &sConfig, DAC_CHANNEL_2) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN DAC_Init 2 */
  /* USER CODE END DAC_Init 2 */
And in this HAL document, it says:
My question is in the generated code there is no separate codes for DAC1 and DAC2. There is only:
How come one line of code sets both DAC output buffer types?
    \$\begingroup\$ The line of code you're looking at is only loading values into the sConfig struct. That same struct is then used in HAL_DAC_ConfigChannel for both DAC_CHANNEL_1 and DAc_CHANNEL_2. Just look at the comments in the code which CUBE_MX generated for you... \$\endgroup\$
    – brhans
    Feb 28, 2022 at 13:00
It's only a matter of how the code is written.
The structure sConfig is created once, and used twice when calling HAL_DAC_ConfigChannel(), once for each channel. Since both channels have the same settings, this works fine.
If the two channels had different settings, sConfig would have been modified between the two usages.
