When I only have two components (for example a Module and a heat sink), what thermal equivalent circuit models (Cauer or Foster) should I use to represent it?
\$\begingroup\$ You should read this assets.nexperia.com/documents/application-note/AN11261.pdf \$\endgroup\$– Antonio51Mar 1, 2022 at 13:56
\$\begingroup\$ @Antonio51 I already did but still dont understand. Personally i would use the Cauer model but I only have to components so Im not sure if its the right model \$\endgroup\$– YooYeeMar 1, 2022 at 17:27
Add a comment
