I'm designing a 4-layer PCB with the SIGNAL/GND/POWER/SIGNAL stackup.
Since I have a dedicated ground plane layer, I've decided not to pour ground connected copper on the top and bottom signal layers, as I've read in other topics on the exchange that pouring ground on these external signal layers while already having a dedicated ground plane layer will bring little to no benefit, and might create EMI problems.
But, here's the thing : I have I2S traces running at roughly 12 Mhz, as well as some SD card interface traces which run at 50 MHz. I believe the rise times for these are gonna be pretty short, so the signals on these are (if I'm not wrong) going to want to follow the trace path for their return current, not the shortest path.
And some of these signals go through vias between the 2 signal layers. When changing layer, the return current is gonna seek for the nearest path to the reference plane, which would be, for example, the nearest capacitor ground via or MCU ground pin via. Again, my knowledge of grounding is limited but I believe that this would create a ground loop. My board is audio oriented and I wouldn't want to hear the induced "hum" sound in the audio output...
Pouring copper connected to the ground plane and "sprinkling" some ground vias in this copper pour area would allow for short paths to ground pretty much everywhere on the top/bottom layers, reducing the size of ground loops, but again as I said in the first paragraph some say that it can bring EMI problems (such as the pour acting as an antenna).
Should I pour ground on the top and bottom layers or not ? Answers on similar questions had a vague conclusion, some saying yes, some saying it is not necesary but can be done, some saying no, don't do it...
