I am trying to get my head around the effects of interference on a wireless signal and its signal strength. I do not have an engineering background, but I do have a background in wireless sensor networking (from the MAC layer up.)
Imagine following scenarios:
- (a) A transmitter TX that transmits packets to a receiver RX in a room. Let's assume a free-space, line-of-sight transmissions from TX to RX. The received signal strength (RSSI) of the packets received at the receiver is -100 dBm (I took a random strength here.)
- (b) The same scenario as (a), but now there are interfering transmissions in the room, on the same frequency channel.
Let's say that the packet reception ratio (PRR) is 100% in scenario (a), as the receiver sensitivity is lower (i.e., -120 dBm in my imagined scenario) than the -100 dBm.
In scenario (b) I assume the PRR will be < 100%, let's say 70%. I am trying to fully understand what the effect is of interference on the packets at RX:
- For packets not received at RX anymore (i.e., the 30% of the transmitted packets,) did the interference lower the RSSI too low < -120 dBm, or how does interference "screw" up the signal so it can't be demodulated anymore?
- For the packets that are still correctly received (the 70% of the transmitted packets,) does interference lower the RSSI of these packets received at RX, will the average RSSI be lowered to a RSSI between -120 dBm and -100 dBm (so still above the sensitivity threshold,) or does interference not decrease the signal strength of our transmission?
When I search for research about the effects of interference on a transmission (e.g. among others [1]), the authors rather talk about how the SIR (signal-to-interference ratio) affects the PRR, but never mention how it affects the RSSI. I am wondering if the RSSI of a tranmission in the presence of interference iss affected, that is, is lower or not?
