I need to make a footprint for a USB type C connector in Altium, and two of the shield pads are shaped like an L. Technically this is a component for Altium 365, but I'm not sure that will make a difference. For the life of me, I can't figure out how to reproduce the drawing. The closest I can get is adding two pads, naming them the same and overlapping them. Altium throws a warning when I do that though.
\$\begingroup\$ Duplicate of this question: electronics.stackexchange.com/questions/597552/… \$\endgroup\$– Spehro 'speff' PefhanyCommented Mar 8, 2022 at 21:30
1\$\begingroup\$ Does this answer your question? How can I make this kind of hole or drill in Altium? \$\endgroup\$– JYeltonCommented Mar 8, 2022 at 23:34
Add a comment
1 Answer
Look into a plated routed hole
2\$\begingroup\$ Can you expand this answer? \$\endgroup\$– Voltage Spike ♦Commented Mar 8, 2022 at 22:22
