I have a PCB that has 2 Ethernet ports (tested card). I'm building a test bench that I will connect to my PC, the goal is to test if the 2 ports are working.
The PCB doesn't have Ethernet female connector just pogo pins to touch the ethernet connections, then the connections go to 1 Ethernet female connector that I plug to my PC.
I want to make some switch on the test bench PCB so I can select if I want the port A or the port B of the tested card. The switch would be a +5V/+12V/any required voltage signal.
In other words I want a multiplexing IC where I can select the output Ethernet port.
What would be an IC or the name of this idea? I can't put a name on this and multiplexing ethernet doesn't show anything.
