Electrolytic capacitors can only be biased by one polarity of the voltage.
I am having a hard time understand how to connect a electrolytic capacitor to a voltage source.
The symbol of a electrolytic capacitor is:
and when I see a electrolytic capacitor I have something like this:
Now there is a strip with a - sign on it so I guess that side of the capacitor will go to the lower voltage correct?
  • \$\begingroup\$ duckduckgo.com/… \$\endgroup\$
    – jsotola
    Commented Mar 12, 2022 at 18:18
  • \$\begingroup\$ As others have noted, the symbol you show is incorrect. That is the symbol for a variable capacitor. \$\endgroup\$
    – user57037
    Commented Mar 12, 2022 at 18:20
Yes, correct. On the picture you posted the dashes indicate the negative terminal of the capacitor, and the other is the positive terminal.
  • \$\begingroup\$ The negative terminal is also the shorter leg (assuming no one has been at it with side-cutters yet!). \$\endgroup\$
    – Rohan
    Commented Mar 13, 2022 at 3:09
The symbol you have shown is incorrect.
Here's the correct one.
On the component, however, the -ve terminal is marked.
  • \$\begingroup\$ This is the correct symbol, but often the '+' is omitted. \$\endgroup\$
    – user57037
  • \$\begingroup\$ 62 years ago the positive terminal of an electrolytic capacitor was marked "+" and the negative terminal was not marked. \$\endgroup\$
    – Audioguru
    Commented Mar 12, 2022 at 21:16
