I have a chip that operates on 1.8V Vcc and has a digital interface I2C that also obviously outputs 1.8V signals and receives 1.8V signals. The datasheet says anything above 2V on VCC or digital input pins is fatal.
I want to interface this to a 3.3V micro controller dev board (which has its own
I have one 1.8V regulator that can output up to 1A. I also have some 2N4403 and 2N4401 and some resistors at hand.Is there a way that I can create a 1.8V to 3.3V and 3.3V to 1.8V with some passive components?
I have +5V/2A, +3.3V/1A and 1.8V/1A supply rails on my bread board.
If not, I would assume I will need a transciver or logic translator chip? Can you recomment me a few if possible?
Update:
I found the circuit below, but I guess 1.8V is not enough to switch mosfets on/off.... is there any trick I can use with just my NPN/PNP jelly bean transistors?
The trick you can exploit with I2C is that it is open collector. This simplifies translating voltage somewhat.
But rather than raiding your parts bin, consider using a translation IC. Here’s a bunch from NXP: https://www.nxp.com/products/interfaces/ic-spi-serial-interface-devices/ic-voltage-level-translators.
  • \$\begingroup\$ Thanks for your answer. How can I exploit open collector? \$\endgroup\$
    – DEKKER
    Commented Mar 13, 2022 at 21:52
    \$\begingroup\$ The fact that I2C only sinks current makes it easier to deal with for voltage translation. Put the pull-up in the 3.3V domain and it covers the translated-down 1.8V too. \$\endgroup\$ Commented Mar 13, 2022 at 23:39
