(EDIT: Added TMR0 & TMR1 set-up code)
I have a small robot vehicle controlled by a PIC18f4585. It has two wheels (ball bearing on the front) as well as two rotary encoders. The following function is supposed to travel a specified distance in inches perfectly straight. It travels straight enough, the problem is the distance. the travelled distance has an error of up to 2cm. I was just wondering whether anyone else could see an error I have missed.
Additional info: The PIC is clocked at 40MHz. I am counting the encoder ticks using TMR0 and TMR1 in 8-bit mode.
Any help/suggestions would be greatly appreciated, thanks.
TMR CONFIG:
TRISAbits.TRISA4 = IO_INPUT;
OpenTimer0( TIMER_INT_OFF &
T0_8BIT &
T0_SOURCE_EXT &
T0_EDGE_RISE &
T0_PS_1_1 );
TRISCbits.TRISC0 = IO_INPUT;
OpenTimer1( TIMER_INT_OFF &
T1_8BIT_RW &
T1_SOURCE_EXT &
T1_PS_1_1 &
T1_OSC1EN_OFF &
T1_SYNC_EXT_ON );
MOVE STRAIGHT FUNCTION:
void moveForwardDistance(double distance, int power)
int tickGoal = distance * 5.13348; //This seems to get ~the correct distance
int masterPower = power;
int slavePower = power;
int error = 0;
int kp = 50; //error factor
int totalTicks = 0; //used to keep track of total ticks
resetEncoder();
while(totalTicks < tickGoal)
SetRightMotor(masterPower);
SetLeftMotor(slavePower);
error = TMR1L - TMR0L;
slavePower = power + (error / kp);
resetEncoder();
DelayMs(100);
totalTicks += TMR1L;
SetRightMotor(0);
SetLeftMotor(0);
DelayS(1);
