I've built something like this
Schema
for using MCU pins as a joystick controller for a Sega Master System (and the pins are driven from a USB HID device connected to the MCU, but that doesn't matter).
The question is: what is the lower current to drive T1 (I'm using a C1815 because I had this one but I can change it)?
Is it better to keep current as low as possible?
Do I need R2 at all (the standard button seems to have 0-20 Ω resistance)?
The posted solution is working fine as is; I just want to know if I can make it better.
edit: MCU side is 3.3V, max pin current is 16mA Errata: R1 is 20k not 20M
  • \$\begingroup\$ There is an error on image and R1 is 20k not 20M \$\endgroup\$
    – Selvin
    Commented Mar 14, 2022 at 17:37
  • assume internal pullup is 10k to 5V = 0.5 mA
  • assume switch gain = 10 to 20 MAX for Ic/Ib when saturated as a switch or 10% of linear hFE Max
  • choose Re=0
  • compute Rb = 10% of 0.5 mA = \$ I_B= 50 uA => R_B= \dfrac{3.3~V - 0.6~V_{=V_{be}}}{0.05 ~mA }=54 ~k\Omega \$ will probably work but with capacitance on cable, use 1k to 10k
R2 can be 0 ohms so removed and replaced with a short circuit.
R1 is at least 1000 times too large and can be one 10000th in value. Just use something like 2k to 10k.
  • \$\begingroup\$ Acctually there is an error in image and R1 is 20k \$\endgroup\$
    – Selvin
    Commented Mar 14, 2022 at 17:42
