I need an estimate of how many watt hours a battery has gained after charging to a certain number of volts.
With a 12 V, 50 Ah lead-acid car battery, charged from 12.5 V to 13.0 V, is it as simple as this?:
(13.0 V - 12.5 V) * 50 Ah = 25 Wh
This only needs to be an estimate. The battery powers a load with a constant draw that turns on and off 5-20 times per day, so I know how long it can run on a given number of watt hours, and just need an idea of:
'If I charged this many volts, I can expect this many extra watt hours available for spending'.
