I have developed an application using the CYBLE-222014-01 module which acquires a set of data and transmits it over BLE. Now I would like to add OTA functionality to this project, however the application note is not that clear when explaining how a fixed stack bootloader is to be implemented. If anyone has a clearer idea it would be greatly appreciated.
Thanks!
  • \$\begingroup\$ Are you aware of the 50-page application note AN-97060, which is a Guide to OTA Firmware Update for your module? \$\endgroup\$ Mar 18, 2022 at 19:39
  • \$\begingroup\$ Yes, but this application note is not that clear on the actual implementation of the code itself. Thanks \$\endgroup\$
    – Chris_26
    Mar 21, 2022 at 6:20
  • \$\begingroup\$ Looks like there are example projects and step-by-step instructions of how to combine their fixed-stack bootloader project with your BLE project. If still stuck, you could try the Infineon (which bought Cypress) community forums for specific help. \$\endgroup\$ Mar 21, 2022 at 16:01
  • \$\begingroup\$ Ok, will do thanks a lot ! \$\endgroup\$
    – Chris_26
    Mar 23, 2022 at 6:31
