tomorrow I'll have a lab class and we were told what we'll do in advance. So, since I don't want to be unprepared I started thinking about how to "solve" the problems, and I'm hardstuck at this one.
We have an HP33120A aribitrary waveform generator (AWG) and a MOD-U1272A multimeter. The problem is to have the AWG set to generate a sine waveform with given parameters, and I can do that, and then measure the VPP through the multimeter. If I can connect everything correctly* then I should be able to read on the MOD-U1272A's display the RMS of the wave, which is VP/sqrt(2), and then calculate the VPP from it.
The point is, I don't really know how to connect the multimeter to the AWG, especially, where should I connect the COM probe of the multimeter? I think I should need a common voltage reference for both the AWG and multimeter but the HP33120A doesn't have a GND connector if I saw correctly. Then how should I do it?
Thanks in advance, this managed to made me kinda nervous and it would be a great relief if I managed to find out.
