I have an old AC transformer with many taps off it at different voltages. Connecting a voltmeter to tap 2 and tap 3 gives 25V and connecting it to 3 and 4 gives 5V. I connected them to two bridge rectifiers, so the rectifiers now output 25V and 5V DC. I needed a common ground for the two currents, so I put a wire between the DC grounds of the rectifiers, but now they give the wrong DC voltages (~18V and 33V, if I remember correctly). What am I doing wrong?
While I have not run any time-based analysis of the described circuit, I see a problem with the ground connection. As you suggest, ground connections are used to connect ground of multiple isolated rectifiers or other floating supplies. However, since both rectifiers use the same input pin (3), they are not isolated from each other.
Since the shared connection creates a virtual node at which voltages at location 2 and 4 are phase-shifted by 180 degrees, the two rectifiers indeed do not work as intended. Try connecting one input between 2 and 4 and the other one between 2 and 3 and see if that would work for you.
Flybacks converter with multiple outputs have usually multiple galvanically isolated winding.
  • \$\begingroup\$ I tried putting them as you said, and I also tried various other combinations where they don't share any taps, however the lower voltage was always still off \$\endgroup\$ – zacaj Mar 18 '13 at 20:13
  • \$\begingroup\$ I see. Do you use the full-wave rectifier or half-wave rectifier? Half-wave rectifiers should work just fine because the grounds are effectively shorted on the AC side (AC input A : (3) - (2), B : (4) - (2)). I have posted schematics here: i48.tinypic.com/2cpyeyq.jpg \$\endgroup\$ – SunnyBoyNY Mar 18 '13 at 21:59
  • \$\begingroup\$ It is a full wave rectifier, media.digikey.com/pdf/Data%20Sheets/Vishay%20Semiconductors/… to be precise \$\endgroup\$ – zacaj Mar 18 '13 at 22:06
  • \$\begingroup\$ Looks like an easy fix -- try using just two diodes instead of four to change the rectifier topology to half-wave (the unused two diodes will be in series anode-to-anode). It should work if you do so. \$\endgroup\$ – SunnyBoyNY Mar 18 '13 at 22:30
  • \$\begingroup\$ I forgot to mention that full-wave rectifier will not work due to its ground loops formed by diodes in the two full-wave rectifiers. \$\endgroup\$ – SunnyBoyNY Mar 18 '13 at 22:31
