I have a circuit that is supposed to run four 12 V DC motors with built-in motor drivers off of one LiPo battery. The LiPo battery (single cell 3.7 V) is boosted to 12 V (the converter circuit is rated for 1.75 A) and the 12 V line is connected to four separate motors on the PCB.
When I flip the power switch with more than one motor connected, the power LED immediately turns off and the battery only outputs 2.5 V (the battery is fully charged and outputs 4.2 V with the circuit off). When connecting a single motor by itself, there are no problems, the motor runs perfectly.
The battery is a 6000 mAh battery, with a supposed .5C continuous discharge current allowed with a maximum of 1C discharge current. I measured the current that one motor by itself takes when hooked up to a 12 V power supply, and I found a single motor draws 70 mA of current. In my eyes, four motors should not be causing an overcurrent issue with the battery, if that is their current draw.
What could be the cause of the battery shut-off? I have included the useful parts of my schematic below.
Battery to 12 V converter
12 V to load switches that control motor power on/off and the four motor pin headers
UPDATE: If I turn on the circuit with one motor connected and then connect the other three the battery never turns off and all four motors work at full speed. The turning-off behavior only happens when all four motors are connected before the power is turned on.
