OK here's the deal, KiCAD of course does a wonderful job with schematics, footprints, Gerber files, they even provide a pretty decent autorouter. Then you take the Gerbers and Excellons over into FlatCAM and they use those to make geometries and "job files" (G-code).
And so far I just have a minimal 3018 machine (probably a RATTM controller, I'm not sure) running GRBL 1.1h and I talk to it with LaserGRBL (even though I have no laser). Well I though I was on top of the world until I tried actually executing the G-code corresponding to the Excellons (drills), which of course were at several different diameters, so when I generated those files I clicked on "tool change", but when I tried to run the resulting file into the machine it choked on the "M6" (tool change) code generated.
Well at THIS price I obviously realized I wasn't getting any AUTOMATED tool change, but I DID expect the machine to stop and notify me SOMEHOW that it was time to go to the next tool (drill). Well then I unchecked "tool change" and went through the same procedure, and I looked at the G-code and saw to my horror that it had generated code to drill ALL the holes with the initial drill diameter in the machine!
Well I don't know what command exists in G-code to "halt for intervention", and if there were one I wouldn't want to manually edit it into ALL these job files, and I suppose "worst case" I MIGHT have to break all these job files into a SEPARATE file for each diameter, what a PITA!
So what I want to know is what are my alternatives for an even SLIGHTLY "enlightened" code stack? Is there a credible "alternative" for either GRBL or FlatCAM so I don't have to completely "invent a new workflow" JUST to accommodate the "revelation" that - wait for it - holes in PCBs occasionally actually have MORE THAN ONE diameter?
Has anyone else found a simple way to circumvent this? (I mean what a letdown after SO MANY other problems in this flow have finally been resolved!) Thank you in advance for your time and insight!
Use the Excellon preprocessor in Flatcam that excludes the M6 code, which should be GRBL_11_no_M6 or something similar.
Set up your desired tool change position too, obviously.
  • \$\begingroup\$ OK a preprocessor...who knew... \$\endgroup\$ Commented Mar 24, 2022 at 9:06
