I am looking for a solution to cycle power to a pump. Below, I am referencing the thought on this device as the 'solution'.
Situation: I have a 110V 25A (maximum draw under load) pump that is powered by an inline float valve switch. (A piggyback plug to which the pump plug plugs in.)
Work around today: Pump generally runs without issue until the 15 gallon tank is emptied but on occasion, the liquid being pumped may cause backups in the line. By unplugging the power source and plugging back in, the fluid is jarred enough to cause the pump to finish pumping the liquid out of the tank. On occasion, it may take several plug/unplugged events to finish the pumping of liquid.
Theorized 'solution': Place a solution between the switch and the pump that would initiate a 5 min run cycle. The float valve switch turning off the power before the 5 minutes is up would indicate a no issue run cycle result. If the pump runs through the 5 minute run cycle, the solution would interrupt power to the pump for 1 minute and then initiate another 5 minute run cycle. This 5 minute ON 1 minute OFF cycling of the pump would replicate the work around being performed today.
Environmental: there would be no power to the solution until the float valve switch energizes the solution so the solution would require its own power source, run on battery or once energized, just begin the 5 - 1 cycle.
Any thoughts on a solution would be most appreciated.
