When a magnet is moving toward a wire loop north-side first, the current goes counterclockwise according to the magnet's perspective, as shown in the image below from Wikipedia. Now, consider a solenoid where each loop is wound so that travelling counterclockwise (again, as seen from the magnet) takes you toward the magnet. If the magnet were to be moved toward this solenoid like it was moved toward the wire loop, the current would still travel counterclockwise, which, as we just stated, means that the current will also travel toward the magnet.
What would happen if the solenoid was wound the other way, i.e. so that travelling counterclockwise takes you away from the magnet? Would the current travel away from the magnet if we moved the magnet toward the solenoid as we did before? I've asked my physics teacher and googled a ton of stuff related to Lenz Law but haven't found an explanation.
Thanks!
