CADe SIMU is a industrial circuit drawning and simulation software.
I have troubles with the icons size and some bugs, so I am looking for an alternative to CADe SIMU.
I found good softwares to draw but do not allow you simulate the circuit.
I want to simulate contactors, sensors, motors, thermal relays, PLC and so on.
The CADe SIMU runs those components, but I need and alternative to this software.
Thank you.
  • \$\begingroup\$ There are a lot of good alternatives out there, do some searching. However, I am unaware of any that will "simulate a PLC". What does that really mean? Do you write you PLC code and the simulator will run that code and turn on / off IO? \$\endgroup\$
    – Tyler
    Mar 28, 2022 at 13:19
  • \$\begingroup\$ @Tyler could you say some of these good alternatives for CADe SIMU (preferably free to use)? \$\endgroup\$
    – Guilherme
    Oct 4, 2022 at 15:54
