This circuit contains forward and reverse bias. The question is to find Vd and Id. In this case, my understanding is that the current from the leftmost mesh will not flow to the middle and rightmost mesh due to reverse bias. In another case, the current from the middle and rightmost mesh will not will into the leftmost mesh because of the reverse-biasing condition (negative terminal of diode connected to the positive terminal of external voltage).
First, in the leftmost mesh, I solve using Ohm's law to find the respective current and voltage.
Second, the middle and rightmost mesh, I apply Thevenin's theorem to find the Vth and Rth.
But then, I am stuck with the subsequent steps. Any guidance/suggestions are welcomed. Thank you.
