I want to assign signals of a testbench to a component to which the port have infered constraints. I would like to introduce the problem with a working workbench before moving to a minimally reproducible example.
Example with constraint inference
Assume A and B
A.vhdl (the testbench)
library IEEE;
use IEEE.STD_LOGIC_1164.all;
use IEEE.NUMERIC_STD.all;
entity A is
end entity;
architecture A_arch of A is
signal input, interm, output : std_logic_vector(10 downto 0);
begin
B1: entity WORK.B port map (
X => input, Y => interm
B2: entity WORK.B port map (
X => interm, Y => output
process begin
input <= (1 => '1', others => '0');
wait;
end process;
end architecture;
B.vhdl (component under test)
library IEEE;
entity B is
port (
X : in std_logic_vector;
Y : out std_logic_vector
end entity;
architecture B_arch of B is
begin
Y <= X;
end architecture;
As we can see, the size of B.X
is inferred and everything compile just fine.
Example with different types
Again I would like to test B, except I would like to have X : signed
and Y : unsigned
instead. Their constraints are not (yet) inferred.
A.vhdl
X => unsigned(input), std_logic_vector(Y) => interm
X => unsigned(interm), std_logic_vector(Y) => output
B.vhdl
entity B is
port (
X : in unsigned(10 downto 0);
Y : out signed(10 downto 0)
end entity;
begin
Y <= signed(X);
end architecture;
The minimally reproducible failing example
and Y : unsigned
instead with their constraints inferred.
B.vhdl
entity B is
port (
X : in unsigned;
Y : out signed
end entity;
begin
Y <= signed(X);
end architecture;
B compile just fine but I can't seem to figure out how to handle the port mapping in A.
attempts
as is
Of course, it doesn't work because of the types differences.
with casting
from this post
begin
** Warning: A.vhdl(12): (vcom-1191) Type conversion on actual associated with formal > "X" must be a constrained array subtype.
** Error: A.vhdl(12): (vcom-1189) Type conversion on formal "Y" must be a constrained > array subtype.
** Warning: A.vhdl(16): (vcom-1191) Type conversion on actual associated with formal > "X" must be a constrained array subtype.
** Error: A.vhdl(16): (vcom-1189) Type conversion on formal "Y" must be a constrained > array subtype.
