I designed a multiple feedback bandpass filter using the Analog filter wizard. The design is purely education therefore I used ideal op-amp. Fc = 50KHz; DC gain = 6dB; Q = 5;
I followed the instructions included in the AD tutorial “Stability of Op-Amp Circuits” and simulated the circuit in the same fashion. LTspice: Stability of Op Amp Circuits | Analog Devices
My recollection from control systems is that the negative feedback circuit is stable as long as we do not invert the signal by 180° with a magnitude equal to or greater than 0dB to prevent oscillation. If correct my 0dB point is at 10Mhz and I have 93° of phase margin. Which is sufficient. Additional circuit never reaches the -180° phase shift. However, at 90KHz the phase shift equals 164° with 22.7 dB of gain. I would imagine that it is a very low phase margin of only 26° with 22.7dB of gain. I vaguely remember the “rule of thumb” for phase margin as 45° and gain margin as 20dB.
If the above statements are correct are they applicable for filters?
If yes how can I improve the phase margin? Would the introduction of a delay in order to shift the phase response be a good idea?
