Just spent a long time on the JST site and the Molex site trying to identify the following connector. It's got 2mm pitch and is used for a battery connector in a small RC quadcopter.
I found them on AliExpress listed as "MX 2mm" at https://www.aliexpress.com/item/4000639410772.html. MX = Molex?
This UK site here http://www.micronradiocontrol.co.uk/conn_molex2mm.html simple named them "Molex 2mm".
Yet, I scrolled through the entire Molex 2mm pitch catalogue but none was even close.
enter image description hereenter image description here
  • \$\begingroup\$ Given the fishy electrical tape and the hard to find connector, why not just cut the wires and replace it with something easier to obtain? \$\endgroup\$
    – Lundin
    Apr 5, 2022 at 8:45
After I posted the Q I came across https://connectorbook.com/identification.html. It helped me identify this as Molex (indeed) 51006 + 51005.
  • \$\begingroup\$ Hi, Thanks very much for coming back with the answer to your question. Since you must wait 48 hours after you asked the question before you can accept your own answer, please come back and accept your answer (or another one, if an even better answer is posted in the meantime) after 20:49 UTC on 6 April. Thanks again. \$\endgroup\$
    – SamGibson
    Apr 4, 2022 at 23:54
  • \$\begingroup\$ Hey, that's my site! I am glad you discovered it! \$\endgroup\$ Apr 5, 2022 at 0:27
    \$\begingroup\$ @DavideAndrea Exactly, I found it an an answer of yours for a different question. \$\endgroup\$ Apr 5, 2022 at 11:22
