Needing a dc to dc converter, I thought of using a "flybuck" circuit, I stopped at the IC "AOZ3015AI" (https://www.tme.eu/Document/0262838228a45307035e45b4effa9bb7/AOZ3015AI-DTE.pdf), due to the price accessible. My question is if this circuit is compatible with this application, what features should I pay attention to?
I need for: U1: -20v / I = 50 mA. U2: 3v AC / I = 100 mA.
Example "Flybuck" circuit:
  • \$\begingroup\$ @TonyStewartEE75 - you are mistaken. The poster’s circuit is indeed a “flybuck” it is also not synchronous as it uses D1 not an active switching device. \$\endgroup\$ Commented Apr 5, 2022 at 4:05
  • \$\begingroup\$ I stand corrected. New name to me. ti.com/lit/an/snva790/snva790.pdf?ts=1649077713175 You need better specs for input and tolerance of output then re-read design info until understood \$\endgroup\$
    – D.A.S.
    Commented Apr 5, 2022 at 4:42
