I have a PHY-CHIP with XAUI Interface connected to a A7-FPGA-CHIP(GTP). My schematics say I should reconfigure the "polarity and order" of my incoming and outgoing xaui - GTP Pins.
Here an example:
- phy-xtx0_3N is wired to mgt216RX0P
- but I think it should be to mgt216RX3N
I tried to change my xdc file and I tried to connect the signals in my top lvl.
I get one critical warning like this:
[Vivado 12-1411] Cannot set LOC property of ports, Cannot set PACKAGE_PIN property of ports, port a7_mgt216_rx_p_i[0] can not be placed on PACKAGE_PIN B11 because the PACKAGE_PIN is occupied by port a7_mgt216_rx_n_i[3] ["ts.xdc":25]
But I get like 8 critical warnings of this :
[Vivado 12-1411] Cannot set LOC property of ports, Cannot set PACKAGE_PIN property of ports, port a7_mgt216_rx_n_i[0] can not be placed on PACKAGE_PIN A11 because the PACKAGE_PIN is occupied by port a7_mgt216_rx_n_i[3] ["/home/constraints.xdc":26]
Questions:
What do you think:
Is it possible to change it or is it bad luck if its not wired correctly on the pcb? Is there another XAUI example I could try? I don't think so right? Its rather a very special topic right? In best case I could fix the bad connection between GTP and XAUI right?
what may not work:
xaui< -> transceiver<-> **change order of signals** <-> phy
possible solution:
xaui <-> **change order of signals** <-> transceiver<-> phy
lol i thought is easy but xaui is connected really strange to the transceiver. I thought it would just connect "directly" but there is something in between so I maybe cant change it that easy.
here you can see the entering connections from the phy to the gtp.
Tx0 and Rx2 go to GTP Channel 1 and from there to the XAUI I am really not sure if this will work xD I counted them n/p swapped pairs: 3
can I change this connection from GTP to XAUI Core easily?
What do you think about TX/RX POLARITY it should switch some TX n/p and RX n/P of Channels. Only problem would be mixed up lanes from XAUI to GTP^^
I need to check the Transceiver connections. How is a transceiver normally connected to incoming / outgoing data...
Update:
change the *xci file now:
https://support.xilinx.com/s/article/57546?language=en_US
mgt_txdata_reord(216+15 downto 216) <= mgt_txdata(15 downto 0);
mgt_txdata_reord(316+15 downto 316) <= mgt_txdata(31 downto 16);
mgt_txdata_reord(116+15 downto 116) <= mgt_txdata(47 downto 32);
mgt_txdata_reord(016+15 downto 016) <= mgt_txdata(63 downto 48);
mgt_txcharisk_reord(22+1 downto 22) <= mgt_txcharisk(1 downto 0);
mgt_txcharisk_reord(32+1 downto 32) <= mgt_txcharisk(3 downto 2);
mgt_txcharisk_reord(12+1 downto 12) <= mgt_txcharisk(5 downto 4);
mgt_txcharisk_reord(02+1 downto 02) <= mgt_txcharisk(7 downto 6);
What do you think about it?
(I need also to change the polarity now of some lanes, with the config vector of the transceiver ..
maybe thats all
haha)
