I have stumbled upon this mystery chip, it is probably a voltage regulator. It is inside a projector I want to repair. From what I gather, it's probably a 1.8 volt regulator.
If you can confirm please go ahead. The package is SOT-223.
  • \$\begingroup\$ Week 17 2018? Dead already? \$\endgroup\$ Apr 6, 2022 at 20:51
Dii is the logo for Diodes Incorporated.
At first, "4aG" looks like a possible SMD marking code as this shows several 1.8V regulators, but none by DI. Checking DI datasheets, it looks more like "17-18" is the device marking, "18" being 1.8V and "17" being the model. The only DI datasheet I could find which shows this naming format is this one page 10:
AP7363 Datasheet
So it is definitely a DI linear regulator, 1.8V, model "17", in a SOT-223 package. But none of the models ending in *17 have a datasheet which matches this marking.
Could be that the device was custom-made or is outdated, relabeled, etc.
Chances are good the 63-18 could be an equivalent, but you'll want to make sure the pins are in the same order first of course.
  • \$\begingroup\$ that matches what I have found so far so thank you \$\endgroup\$ Apr 6, 2022 at 22:11
I'm unsure about the first two or three symbols. Looks like an incomplete "DH" or something. But the 17-18 on the second row is at least a little familiar. Onsemi uses that for an obsolete 1.8V regulator with part number NCP1117ST18T3.
