I've just had my first go at getting a shift register to work with my Arduino.. it was almost flawless, but I seem to be missing my first bit.
I followed the guide here, but using only one shift register: http://arduino.cc/en/Tutorial/ShiftOut
It took a little while to figure out, but it appears as though pin Q1 on my shift register is lighting up when I send the number 2, Q2 is high for 4, Q3 = 8 etc.. when I call shiftout() with the number 1 no LEDs come on.
I checked my wiring and it seems fine.. then I double checked and it's definitely fine.
The only things I can think of are: 1. My shift register is slightly different to the one they're using.. it's a 595N, not a 595. 2. I've done something wrong in the code..
In loop():
  digitalWrite(latchPin, LOW);
  shiftOut(dataPin, clockPin, MSBFIRST, 1);
  digitalWrite(latchPin, HIGH);
Does anyone have any tips on debugging this issue?
Cheers, John
  • \$\begingroup\$ It also got me wondering what Q0 is on pin 15.. \$\endgroup\$
    – John Hunt
    Mar 19, 2013 at 14:42
  • \$\begingroup\$ Q0 is the lowest order output - it's very common (though not universal) for these to be numbered from zero rather than from one. This may well explain why you are getting a different than expected result. Otherwise, you may have one too few or too many clocks. If you had written the shift function yourself, it would also be possible that you were presenting the data at the wrong time relative to the clock, but the library routine is probably OK. \$\endgroup\$ Mar 19, 2013 at 14:56
  • \$\begingroup\$ Upon further inspection of the Arduino tutorial my mind totally skipped over the fact they were using Q0 - the pin out layout on the circuit diagrams is slightly different from the phillips datasheet. This makes it all make sense :) \$\endgroup\$
    – John Hunt
    Mar 19, 2013 at 18:50
7
The shift register is behaving exactly as designed.
The second-from-lowest significant bit should be lighting up for a value of 2. That's Q1.
To check for a value of "1", you need to be looking at the least significant output bit, which is Q0.
Also, the 595 and 595N are not functionally different.
  • \$\begingroup\$ Thank you for confirming that :) I like shift registers! \$\endgroup\$
    – John Hunt
    Mar 19, 2013 at 16:38
  • \$\begingroup\$ @JohnHunt Yes, they're neat... Even neater are the high current shift registers like TPIC6A596, which can actually sink 350 mA per bit, and can be used to directly control relays, solenoids and entire LED strings! \$\endgroup\$ Mar 19, 2013 at 16:48
I'm no good on code but maybe you are trying to latch the data to the output before it is properly clocked in to the internal shift register? This could result in the data bit previously clocked into the shift register popping up on the output. This could give you what you see. Maybe you need a small delay after the shiftOut command. Or maybe i'm being stupid?
