An old CRT I have specifies 6.3 V (DC, I believe) on the heater filament, resulting in a 0.6 A filament current (spec).
But I measure the filament resistance as 1.8 Ohm.
At V = 6.3 V that would result in a 3.5 A filament current, about 6 times too high!
I'm tempted to measure the filament current with a 6 V DC battery pack but I'm afraid to burn the filament?
Any advice is appreciated!
  • \$\begingroup\$ If you try ... do it slowly. The filament must be "just" a little "red", ... if you see it ... \$\endgroup\$
    – Antonio51
    Commented Apr 7, 2022 at 18:09
    \$\begingroup\$ Also at 6.3V, the supply was usually AC (though DC would work and it was designed to be compatible with 3 cell Lead Acid. \$\endgroup\$
    – user16324
    Commented Apr 7, 2022 at 19:39
1.8 ohms is the cold resistance; it will increase as the filament warms to operating temperature.
  • \$\begingroup\$ Ah. That solves it. I didn't think the effect of temperarure would be that large. Accepted. \$\endgroup\$
    – Gert
    Commented Apr 7, 2022 at 19:23
  • \$\begingroup\$ It's probably >6x R increase at 1500'K \$\endgroup\$
    – D.A.S.
    Commented Apr 9, 2022 at 14:13
